15 years agoCritical Warning: Timing requirements not met and SRAM problems
Hello
I had a design that works properly on a DE2 board. I am trying to implement the same design on a DE2-115 board, and I found some troubles. The design seems to work well until I try to use the NIOS II with the external SRAM memory. When I try to debug the software (and, a simple "Hello world", too), memory validation fail. I modify just a bit the vhdl code and recompile and it seems to work.... I modify just a bit the vhdl code and recompile and it doesn't work.... Finally I find the following warning: "Critical Warning: Timing requirements not met" Could it be the cause of my trouble? How can I fix it? Sorry for my poor english sintaxis. Thanks.2 Replies
Well, put simply, "Timing requirements were not met" and thus your design will, probably, not work.
You need to track down the failing paths and see why they're failing. - Altera_Forum
search for the timequest tutorial at www.alterawiki.com
