15 years agoCritical Warning: Timing requirements not met and SRAM problems
Hello I had a design that works properly on a DE2 board. I am trying to implement the same design on a DE2-115 board, and I found some troubles. The design seems to work well until I try t...
15 years agoWell, put simply, "Timing requirements were not met" and thus your design will, probably, not work.
You need to track down the failing paths and see why they're failing.
