16 years agoChar Buffer UP IP
Hi
I'm trying to realize a text terminal on VGA display using Char buffer and VGA control available in UP IP v9.0 I've implemented the Nios on a DE1 board. I'm sure that the hardware works properly, since writing a value directly on the mem position, a char appear on the VGA monitor But I've some problem to write a suitable software. I tried with: int main() { int i; alt_up_char_buffer_dev * my_ch_buf; printf( "Nios II Alive!\n\n" ); my_ch_buf = alt_up_char_buffer_open_dev( "/dev/character_buffer_0_avalon_char_buffer_slave"); if ( my_ch_buf == NULL) alt_printf ("Error: could not open pixel buffer device \n"); else alt_printf ("Opened pixel buffer device \n"); i = alt_up_char_buffer_draw(my_ch_buf , 'A', 30,30); printf( "res=%d",i ); } but the answer is :( "Error: could not open pixel buffer device": infact the function "alt_up_char_buffer_open_dev" does not open the device and so the subcessive function "alt_up_char_buffer_draw" is unable to write anything. Any suggestion? Is maybe available some C examples using this device ? Thank you in advance Stefano1 Reply
OK, I solved the problem by myself:
The correct neme of the device was: "/dev/character_buffer_0"; instead of "/dev/character_buffer_0_avalon_char_buffer_slave"; Whoever it is not clear for me where the "name" of the device is assigned i.e. where to find the correct name in the first release I used the name found in "system.h" which was of course wrong.
