16 years agoChar Buffer UP IP
Hi I'm trying to realize a text terminal on VGA display using Char buffer and VGA control available in UP IP v9.0 I've implemented the Nios on a DE1 board. I'm sure that the hardw...
16 years agoOK, I solved the problem by myself:
The correct neme of the device was: "/dev/character_buffer_0"; instead of "/dev/character_buffer_0_avalon_char_buffer_slave"; Whoever it is not clear for me where the "name" of the device is assigned i.e. where to find the correct name in the first release I used the name found in "system.h" which was of course wrong.
