11 years agobasic questions
Hi everyone,
I'm having trouble with the code I posted below. I'm trying to design an ALU and am having conceptual problems. Seems like for the case when sel is "1000" I get errors saying I need to use := I'm actually very confused about the difference between <= and := . Could someone please explain the difference? In any case neither <= or := works with my code it seems. Furthermore could someone explain to me the difference between std_logic_vectors and signed/unsigned numbers? Also for the case when sel is "0010" is it okay for me to make the following comparison: unsigned(temp) > (2**WIDTH)-1 Thank you -------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity alu_ns is generic ( WIDTH : positive := 16 ); port ( input1 : in std_logic_vector(WIDTH-1 downto 0); input2 : in std_logic_vector(WIDTH-1 downto 0); sel : in std_logic_vector(3 downto 0); output : out std_logic_vector(WIDTH-1 downto 0); overflow : out std_logic ); end alu_ns; architecture alu_arch of alu_ns is begin process(input1, input2, sel) variable temp : std_logic_vector(WIDTH-1 downto 0); --variable temp_mult: signed(2*WIDTH-1 downto 0); begin overflow <= '0'; case sel is when "0000" => temp := std_logic_vector(resize(unsigned(input1), width + 1)+resize(unsigned(input2), width + 1)); output <= temp(width downto 0); overflow <= temp(WIDTH); when "0001" => temp := std_logic_vector(signed(input1)-signed(input2)); when "0010" => temp := std_logic_vector(signed(input1)*signed(input2)); if (unsigned(temp) > (2**WIDTH)-1) then overflow <= '1'; end if; when "0011" => temp := std_logic_vector(input1 and input2); when "0100" => temp := std_logic_vector(input1 or input2); when "0101" => temp := std_logic_vector(input1 xor input2); when "0110" => temp := std_logic_vector(input1 nor input2); when "0111" => temp := std_logic_vector(not input1); when "1000" => --temp <= input1 sll 1; temp <= input1(WIDTH-2 downto 0) & "0"; when "1001" => temp := '0' & input1(WIDTH-1 downto 0); when "1010" => temp := input1(width/2 downto 0) & input1(width-1 downto 0); when "1011" => for i in 0 to WIDTH-1 loop temp(i) := input1((width-1)-i); end loop; when others => temp := (others => '0'); end case; output <= temp(width-1 downto 0); end process; end alu_arch;1 Reply
<= is for assigning a signal
:= is for assigning a variable. Signals and variables behave differently. Variables are assigned immediately whilst signals are assigned when a wait occurs or the process suspends. I highly recommend you dont use variables until you unstand the implications of their behaviour. There is nothing you need a variable for - you can do everything you need for synthesis with signals, and it wont give you odd behaviour. Std_logic_vectors are intended to just represent a collection of bits. Unsigned/signed types are meant to represent unsigned/signed numbers.
