Why do I see the mem pins in Quartus for the HPS?
Qsys provides a complete simulation model of the HPS memory interface controller, providing cycle-level accuracy, comparable to the simulation models for the FPGA memory interface.
"The simulation model supports only the skip-cal simulation mode; quick-cal and full-cal are not supported. An example design is not provided, however you can create a test design by adding the traffic generator component to your design using Qsys. Also, the HPS simulation model does not use external memory pins to connect to the DDR memory model; instead, the memory model is incorporated directly into the HPS SDRAM interface simulation modules. Simulation of the FPGA-to-SDRAM interfaces requires that you first bring the interfaces out of reset, otherwise transactions cannot occur."
You can refer here for more information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/external-memory/emi_ip.pdf#page=297
Hopes this helps your confusion.
Regards.
