WGQ
1 year agoWhich Linux Driver Supports Altera FPGA Generic Serial Flash Interface (GSFI) IP Core?
Hello, I am working with an Altera (Intel) FPGA design that uses the Generic Serial Flash Interface (GSFI) IP core to connect to an external SPI NOR Flash device. I am looking for the appropriate Li...
tehjingy_Altera
1 year agoHi
Do you have a follow up question on this?
Jingyang, Teh
WGQ
1 year agoHi Jingyang,
Thank you for your reply.
After further discussion and evaluation, we have decided that a dedicated Linux driver for the GSFI IP is not necessary for our application.
Instead, we will coordinate with the FPGA side to implement the SPI flash read/write logic. On the CPU side, we will use memory-mapped access (via the PCIE) to directly read from and write to the flash. This approach allows us to access the flash as a memory region without the need for a specific driver.
Thank you again for your support and clarification.
Best regards
