Where is cv_bsp_generator.py
Do you have any update?
Can you check my previous respond?
- RPett43 years ago
I'm using the version called out in my original link, which is the tutorial that all things seem to point to for SPL builds. The script is not included in that version. It is included in the version you linked. There seems to be a disconnect between that tutorial and the repo version.
- RPett43 years ago
It would also be nice if the scripts could be ported to python 3 (it's only been out for 15 years), or at least add details to the guide on the easiest way to run them, because simply installing python and running the scripts causes them to crash in several locations: ex, print parenthesis, unicode not defined, str =/= bytes.
- RPett43 years ago
I cannot get the SPL u-boot build to complete. This is the error message:
arch/arm/mach-socfpga/wrap_sdram_config.c:236:2: error: #error LPDDR2 and other DRAM types are not yet supported
Well LPDDR2 is the memory type I am dealing with for my board, and that seems to be a valid selection in the Quartus HPS configuration menu:
<parameter name="HPS_PROTOCOL" value="LPDDR2" />
and that is how the part is advertised on Intel's product webpage:
"Multiport SDRAM controller with support for DDR2, DDR3, DDR3L, and LPDDR2"
So how do I get around this issue?
