GTese
6 years agoWhen I try to makefile the following error was generated. How can fixed this problem?
arm-linux-gnueabihf-g++ ./host/main.o ../common/ocl_util.o ../common/timer.o -o run.exe -L/home/guta/intelFPGA/18.1/hld/board/c5soc/arm32/lib -L/home/guta/intelFPGA/18.1/hld/host/arm32/lib -L/home/g...
GTese
6 years agoThank You!
To compiling the host programming after compiling the kernel code. It means that after generating hardware configuration (.aoco and .aocx) to link the host code.
I used the quartus standard version 18.1. The OS i used is desktop Ubuntu version 18.04.
