When I try to makefile the following error was generated. How can fixed this problem?
arm-linux-gnueabihf-g++ ./host/main.o ../common/ocl_util.o ../common/timer.o -o run.exe -L/home/guta/intelFPGA/18.1/hld/board/c5soc/arm32/lib -L/home/guta/intelFPGA/18.1/hld/host/arm32/lib -L/home/guta/intelFPGA/18.1/hld/host/linux64/lib -Wl,--no-as-needed -lalteracl -lintel_soc32_mmd -lstdc++ -lelf
../common/ocl_util.o: file not recognized: File format not recognized
collect2: error: ld returned 1 exit status
Makefile:151: recipe for target 'run.exe' failed
make: *** [run.exe] Error 1
- FawazJ_Altera
Can you elaborate more what are you trying to generate?
Which quartus version? OS ?
Thank you
- GTese
Thank You!
To compiling the host programming after compiling the kernel code. It means that after generating hardware configuration (.aoco and .aocx) to link the host code.
I used the quartus standard version 18.1. The OS i used is desktop Ubuntu version 18.04.
