TTjel
6 years agoWhat can hang the Cyclone-V system when the open("/dev/mem" , O_RDWR|O_SYNC) command is used?
I can, with Quartus' Platform Designer, build a Cyclone V hard Processor System, which work. But when a make a new Bock Diagram as top level entity and insert the vhdl file (with Hard Processor as a ...
AnilErinch_A_Intel
6 years agoHi
Can you try the following commands separately and let us know the results
- open("/dev/mem",O_RDWR|O_DSYNC)
also
2. open("/dev/mem",O_RDONLY)
Thanks and Regards
Anil
- TTjel6 years ago
Hi, I realise that also printf was hanged and therefore not printed all text to the console. The actual hanging was when I tried to access the memory address. So the 'open' and the 'mmap' of the memory command worked, but when I wrote to the mapped memory the ARM become hanged. This hanging is only happens when the system is made inside a Block diagram and not when I make the same system from VHDL. I speculate that the AXI send a storm of interrupts, which is not handled properly, but I can’t verify that idé. /Tobbe Från: Intel Forums <[email protected]> Svara till: Reply to Forums <1drdnnvptrw40fbp.cfb51zuuucboalmb.fbeqgqhntg3tmrbt@s55fxanfjsu1n6dz.nfctxsznf2ug8i.u-yt3cmag.na37.chatter.salesforce.com> Datum: måndag 13 april 2020 08:56 Till: Torbjörn Tjelldén <[email protected]> Ämne: AnilA_Intel answered you: What can hang the Cyclone-V system when the open("/dev/mem" , O_RDWR|O_SYNC) command is used? Hi Can you try the following commands separately and let us know the results - open("/dev/mem",O_RDWR|O_DSYNC) also 2. open("/dev/mem",O_RDONLY) Thanks and Regards Anil [Bild som tagits bort av avsändaren.]<https://forums.intel.com/0050P000008xy6P?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> AnilA_Intel<https://forums.intel.com/0050P000008xy6P?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> (Intel) Hi Can you try the following commands separately and let us know the results 1. open("/dev/mem",O_RDWR|O_DSYNC) also 2. open("/dev/mem",O_RDONLY) Thanks and Regards Anil [cid:[email protected]] or reply to this email Replying to [Bild som tagits bort av avsändaren.]<https://forums.intel.com/0050P000008yQWm?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> TTjel<https://forums.intel.com/0050P000008yQWm?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> (Customer) asked a question. Tuesday, den 24 March 2020 11:14<https://forums.intel.com/0D50P00004dOkBp?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D&OpenCommentForEdit=1> What can hang the Cyclone-V system when the open("/dev/mem" , O_RDWR|O_SYNC) command is used? I can, with Quartus' Platform Designer, build a Cyclone V hard Processor System, which work. But when a make a new Bock Diagram as top level entity and insert the vhdl file (with Hard Processor as a soc_system component) as symbol, then the Linux-c command open("/dev/mem" , O_RDWR|O_SYNC) will hang the system. [Bild som tagits bort av avsändaren.]<https://forums.intel.com/0050P000008xy6P?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> AnilA_Intel<https://forums.intel.com/0050P000008xy6P?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> (Intel) Hi Can you try the following commands separately and let us know the results 1. open("/dev/mem",O_RDWR|O_DSYNC) also 2. open("/dev/mem",O_RDONLY) Thanks and Regards Anil Monday, den 13 April 2020 07:55<https://forums.intel.com/0D70P000006viDb?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> You're receiving emails when someone "Comments on my posts." To change or turn off Forums email, log in<https://forums.intel.com/_ui/core/feeds/notification/ChatterEmailSettings?setupid=CollaborationEmailSettings&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008yQWm&s1ext=0&emkind=chatterCommentNotification&emtm=1586760906157&emvtk=JJ4bkC9X119gd_A0Ngajos0X96DoJxY2WXUogDt05DM%3D> as [email protected]. Are notifications about this post getting annoying? Reply to this email with the word " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Bild som tagits bort av avsändaren. Forums]
