MV's avatar
MV
3 years ago
Verify BSP settings
I am developing a system using Cyclone V under Linux OS.
Up to now I was focused on rebuilding of the kernel and device tree. The device tree that is loaded contains the HPS peripherals I am looking for with status = "okay"; but the devices do not seem to work. Also cat /proc/interrupts doesn't seem to be showing interrupts associated with some of the peripherals. Would that likely be an issue with my device tree or could that be that the HW is not enabled in my BSP (that I didn't touch since I started with the GHRD). In case of the UART (serial1) I clearly have a Linux driver running on serial0 so I should be covered there.
I realize that the BSP code embedded into the u-boot is responsible for bring-up of the HPS resources that will be used by the kernel drivers.
  • Is there a way to verify that the resource (such as "serial1") is actually enabled from within a running OS?
  • Can one enable a HPS module during run-time or is the bootloader the only place?
Thanks - Martin
  • Got that one resolved!
    I decided to re-build bootloader and tried to follow the GSRD v14.0 - Generating and Compiling the Preloader
    When I copied the binary to my uSD card the system didn't boot - likely some of the important details like partition type etc. I went back to my previous scripts that use mainline u-boot (branch v2019.07).
    After some searching how the BSP specific information gets included into the u-boot-with-spl_DE0.sfp u-boot binary I discovered in the u-boot build tree the file
    board/terasic/de0-nano-soc/qts/pinmux_config.h
    I edited desired "...USEFPGA" values to "1"
        abbreviated ...
    1, /* UART1USEFPGA */ 0, /* CAN1USEFPGA */ 0, /* USB1USEFPGA */ 0, /* I2C3USEFPGA */ 1, /* I2C2USEFPGA */
    rebuilt the u-boot, placed on my uSD card and the previously failing kernel with corresponding drivers and device tree started to work as expected.
    Hoping this may help someone else.
    Martin
  • MV's avatar
    MV
        abbreviated ...
    Martin
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi Martin
    Glad that you able to get the uboot to boot from SD Card.
    There is a much easire method of doing it available here in the link below:
    https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10#Cyclone_V_SoC_45_Boot_from_SD_Card
    Regarding the question that you have. Please find my respond below:
    Once booted you could check the device under the "/dev" directory in the Linux OS.
    The HPS module needs to be enabled during the bootloader.
    tehjingy_Altera
    Hi
    Do you have any question regarding this topic?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Sorry to inform you that, I am taking annual leave next week.
    Please expect some delay in my reply.
    Thank you very much in advance!
    Jingyang, Teh
  • Hi,
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey. You may also select your own Best Answer.
