MF28
4 years agoUsing SoC Interrupts, Timer, ... MakeFile Error / Question
Hello! I am trying to use the interrupts from FPGA to HPS (for example with the buttons of the Cyclone V Board etc). At first I was not able to get the compilation with the makefile to work, si...
EBERLAZARE_I_Intel
4 years agoHi,
I've checked there are no issue with the design files in Quartus, this seems to be an issue with the makefile.
We have an example for Timer, could you try this one and see if you are seeing the same issue there?:
https://github.com/altera-opensource/intel-socfpga-hwlib/tree/master/examples/CVAV
After that, you could make the makefile as the example as how it works with the timer.
MF28
4 years agoHello!
I will try the example as soon as possible and give feedback about it.
BR
