MF28
4 years agoUsing SoC Interrupts, Timer, ... MakeFile Error / Question
Hello! I am trying to use the interrupts from FPGA to HPS (for example with the buttons of the Cyclone V Board etc). At first I was not able to get the compilation with the makefile to work, si...
MF28
4 years agoHello!
I attached a ZIP-File which includes files which result in the said error when trying to compile them via the Makefile. The given error message is the following:
I guess there are no examples available where the Interrupts are used?
Even though the keys and switches of the FPGA are declared as Interrupts in the GHRD.
I also attached the Platform Designer file. However the error of course is happening when compiling the C Code.
