Using SoC Interrupts, Timer, ... MakeFile Error / Question
Are you using your own design or an example design that you get from somewhere?
Also, did you face any Errors in Quartus /Platform Designer/Qsys during compilation?
- MF284 years ago
Hi!
For the FPGA I am using my own design which is based on the GHRD and the provided soc_system file.
The design is working fine and I wanted to now add Interrupts etc. to it. Here is where the errors appear.
I have not faced any errors or anything suspicious in Quartus / Qsys etc. during compilation. Also creating the header files etc. worked always fine. I do not think that it is an error that is somehow connected to the Quartus project. The error occurs when I use the SoC Embedded alt_interrupt , ... files for my c-code. The error appears when cross-compiling on Windows and also when compiling directly on Linux.
As I said I was able to compile my c code before without interrupts but when I want to add the .h and .c files needed for the interrupts and timers the provided error message is thrown. I am also not even using the libraries yet, I just imported them and this already is not working.
But I am not able to find any examples on how to use interrupts with these files online.
