alex_ander
5 years agoUnable to program HPS on arria10
I am trying to program the HPS of the arria10 . I have tried using the command line interface using "quartus_hps" to program the board and have had no success. for example I run the command ...
EBERLAZARE_I_Intel
5 years agoHi,
Are you using the default images to boot you Arria 10 Board?
alex_ander
5 years agoYes I have followed the Development Kit User Guide and made sure all the switches were in the default position. I also tried changing changing SW6.4 to the off position to not load the factory images stored on the board.
I also found this post on the forum where the intel employee made some suggestions to set SW4 to default position, set switch 1 to ON position, and change the TCK frequency to 6Mhz which also did not work.
Thanks Again,
Alex
- EBERLAZARE_I_Intel5 years ago
I mean, are you programming the .sof or .jic? Are you using the GHRD?
To boot the HPS on the Arria 10 it should look like this:
https://rocketboards.org/foswiki/Documentation/A10GSRDBootLinuxFromSDCardLTS
