Unable to program HPS on arria10
I am trying to program the HPS of the arria10 . I have tried using the command line interface using "quartus_hps" to program the board and have had no success. for example I run the command
embedded_command_shell.sh quartus_hps -c 1 -o I
and the output is this:
Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 17.1.1 Internal Build 593 12/11/2017 SJ Standard Edition Info: Copyright (C) 2017 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Thu Jan 21 08:23:12 2021 Info: Command: quartus_hps -c 1 -o I Current hardware is: USB-BlasterII [3-6] Successfully change hardware frequency to 16Mhz Error: Unable to detect HPS device Error: Quartus Prime Programmer was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 213 megabytes Error: Processing ended: Thu Jan 21 08:23:12 2021 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:00
I have also tried using the Quartus Prime Programmer. I will configure the hardware Setup and then auto detect the hardware. It does not give me the exact part number for my board but i can select one that is close to it. for example my board part number is 10AX115S3F45E2SGE3 however the closest option i can choose is 10AX115S3. After choosing this I automatically get an error that says:
Error (18591): Can't recognize the Flash device that attached to device 2. The Flash device is not supported by Quartus Prime software.
Thanks for your time
- EBERLAZARE_I_Intel
Are you using the default images to boot you Arria 10 Board?
- alex_ander
Yes I have followed the Development Kit User Guide and made sure all the switches were in the default position. I also tried changing changing SW6.4 to the off position to not load the factory images stored on the board.
I also found this post on the forum where the intel employee made some suggestions to set SW4 to default position, set switch 1 to ON position, and change the TCK frequency to 6Mhz which also did not work.
Thanks Again,
Alex
I mean, are you programming the .sof or .jic? Are you using the GHRD?
To boot the HPS on the Arria 10 it should look like this:
https://rocketboards.org/foswiki/Documentation/A10GSRDBootLinuxFromSDCardLTS
