TCL Script - Automation of Compilation process and programming SOF file
- 3 years ago
You may checkout this document for all the supported command-line and tcl scripting in Quartus.
https://www.intel.com/content/www/us/en/docs/programmable/683432/22-4/faq.html
The tcl command "execute_module -tool" support these option [-tool <asm|cdb|drc|eda|fit|map|syn|pow|sta|stp|sim|si|cpf|ipg|pfg> ]
I think the asm_sof is an illegal value. And there is no "output directory" option available for execute_module command.
Richard Tan
As we do not receive any response from you on the previous question/reply/answer that we have provided. I now transition this thread to community support.
Richard Tan
Hey Richard,
My updated TCL script:
package require ::quartus::project
package require ::quartus::flow
# Set the project directory
set project_dir "C:/Amir_Berger/Project/Y"
# Set the project name
set project_name "X"
# Set the output directory for compiled files
set output_dir "$project_dir/output_files"
# Set the name of the SOF file
set sof_file "$project_name.sof"
# Set the output directory for SOF file
set sof_dir "$output_dir/$sof_file"
# Open the project
project_open $project_dir/$project_name.qpf
# Complie Design
execute_flow -compile
qexec "quartus_pgm -c 1 -m JTAG -o MILTECH_2024.sof"
The errors I got:
Error:while executing
Error:"qexec "quartus_pgm -c 1 -m JTAG -o MILTECH_2024.sof""
Error: (file "ProgSOF_1.tcl" line 28)
Error: invoked from within
Error:"_source ProgSOF_1.tcl"
Error: ("uplevel" body line 1)
Error:"uplevel 1 $cmd "
Error: (procedure "source" line 5)
Error:"source ProgSOF_1.tcl"
Following this error description, I understand that the problem is related to the "qexec "quartus_pgm.." line, but I don't understand why.
I will appreciate your help
