SPI interface with Nios II
The errors after renaming those variables are mainly due to inappropriate library paths. You have to specify the library paths correctly or move those .h library files to the folder where hello_world_small.c resides. Please find the attached zip file below for your reference.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- sakthi_iitm4 years ago
I had build the .zip file given by you but still getting an error. How to specify the library paths correctly or move those .h library files to the folder ? What are the .h files that I need to move and to which folder?
Can I know from where you got these procedures ?
CODE:
* "Small Hello World" example.
* This example prints 'Hello from Nios II' to the STDOUT stream. It runs on
* the Nios II 'standard', 'full_featured', 'fast', and 'low_cost' example
* designs. It requires a STDOUT device in your system's hardware.
* The purpose of this example is to demonstrate the smallest possible Hello
* World application, using the Nios II HAL library. The memory footprint
* of this hosted application is ~332 bytes by default using the standard
* reference design. For a more fully featured Hello World application
* example, see the example titled "Hello World".
* The memory footprint of this example has been reduced by making the
* following changes to the normal "Hello World" example.
* Check in the Nios II Software Developers Manual for a more complete
* description.
* In the SW Application project (small_hello_world):
* - In the C/C++ Build page
* - Set the Optimization Level to -Os
* In System Library project (small_hello_world_syslib):
* - Define the preprocessor option ALT_NO_INSTRUCTION_EMULATION
* This removes software exception handling, which means that you cannot
* run code compiled for Nios II cpu with a hardware multiplier on a core
* without a the multiply unit. Check the Nios II Software Developers
* Manual for more details.
* - In the System Library page:
* - Set Periodic system timer and Timestamp timer to none
* This prevents the automatic inclusion of the timer driver.
* - Set Max file descriptors to 4
* This reduces the size of the file handle pool.
* - Check Main function does not exit
* - Uncheck Clean exit (flush buffers)
* This removes the unneeded call to exit when main returns, since it
* won't.
* - Check Don't use C++
* This builds without the C++ support code.
* - Check Small C library
* This uses a reduced functionality C library, which lacks
* support for buffering, file IO, floating point and getch(), etc.
* Check the Nios II Software Developers Manual for a complete list.
* - Check Reduced device drivers
* This uses reduced functionality drivers if they're available. For the
* standard design this means you get polled UART and JTAG UART drivers,
* no support for the LCD driver and you lose the ability to program
* CFI compliant flash devices.
* - Check Access device drivers directly
* This bypasses the device file system to access device drivers directly.
* This eliminates the space required for the device file system services.
* It also provides a HAL version of libc services that access the drivers
* directly, further reducing space. Only a limited number of libc
* functions are available in this configuration.
* - Use ALT versions of stdio routines:
* Function Description
* alt_printf Only supports %s, %x, and %c ( < 1 Kbyte)
* alt_putstr Smaller overhead than puts with direct drivers
* Note this function doesn't add a newline.
* alt_putchar Smaller overhead than putchar with direct drivers
* alt_getchar Smaller overhead than getchar with direct drivers
*/#include "alt_types.h"
#include "sys/alt_stdio.h"
#include "io.h"
#include "system.h"
#include "sys/alt_cache.h"
#include "altera_avalon_spi.h"
#include "altera_avalon_spi_regs.h"
#include "sys/alt_irq.h"
//This is the ISR that runs when the SPI Slave receives data
static void spi_rx_isr(void* isr_context){
alt_printf("ISR%x \n" ,IORD_ALTERA_AVALON_SPI_RXDATA(SPI_0_BASE)); //This resets the IRQ flag. Otherwise the IRQ will continuously run.
IOWR_ALTERA_AVALON_SPI_STATUS(SPI_0_BASE, 0x0);
}int main()
alt_printf("Hello from Nios II!\n");
int return_code,ret;
char spi_command_string_tx[10] = "$HELLOABC*";
char spi_command_string_rx[10] = "$HELLOABC*";//This registers the Slave IRQ with NIOS
ret = alt_ic_isr_register(SPI_0_IRQ_INTERRUPT_CONTROLLER_ID,SPI_0_IRQ,spi_rx_isr,(void *)spi_command_string_tx,0x0);
alt_printf("IRQ register return %x \n", ret);//You need to enable the IRQ in the IP core control register as well.
IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_0_BASE,ALTERA_AVALON_SPI_CONTROL_SSO_MSK | ALTERA_AVALON_SPI_CONTROL_IRRDY_MSK);
//Just calling the ISR to see if the function is OK.
spi_rx_isr(NULL);
return_code = alt_avalon_spi_command(SPI_0_BASE,0 ,1, spi_command_string_tx, 0, spi_command_string_rx,0);
return_code = alt_avalon_spi_command(SPI_0_BASE,0 ,1, &spi_command_string_tx[1],0, spi_command_string_rx,0);
return_code = alt_avalon_spi_command(SPI_0_BASE,0 ,1, &spi_command_string_tx[2],0, spi_command_string_rx,0);
return_code = alt_avalon_spi_command(SPI_0_BASE,0 ,1, &spi_command_string_tx[3],0, spi_command_string_rx,0);if(return_code < 0)
alt_printf("ERROR SPI TX RET = %x \n" , return_code);
alt_printf("Transmit done. RET = %x spi_rx %x\n",return_code,spi_command_string_rx[0]);
//RX is done via interrupts.
alt_printf("Rx done \n");
return 0;
}- sakthi_iitm4 years ago
Error message that i got.
- ShengN_altera4 years ago
#include "io.h"
#include "system.h"
#include "sys/alt_irq.h"May go to your folder nios_spiv1 and search for alt_types.h, alt_stdio.h, io.h, system.h, alt_cache.h, altera_avalon_spi.h, altera_avalon_spi_regs.h, alt_irq.h and copy their paths from properties then specifying them in #include.
Or move those .h files to .../nios_spiv1/software/nios_spiv1 folder where hello_world_small.c resides.
