jjac705
3 years agoSoC EDS issue
I attempted the SoC EDS as per the pdf SoC_software_lab_16.0.pdf on rocketboards.org. I was asked to see the link to create a u-boot-socfpga. In that, it was told to clone a github file which ...
aikeu
3 years agoHi jjac705,
Which steps that you fail to perform the bulid? Firstly you will need to decide where you system booting up from(etc, sd-card or qspi ..). Can show me the steps where you fail to build then I will look into it.
There are pre-built images that you can find in the link below for working comparison just in case you have problem with your build. You can compare with the working ghrd if your system does not boot up properly.
https://releases.rocketboards.org/ghrd_release/
Aik Eu
