SOC EDS installation issue
- 4 years ago
i doubt my corporation firewall blocked the file download, and i tried to download the file "alternatives-1.3.30c-10.tar.bz2" from the link per the setup.log, then copy it to the foler: "C:\intelFPGA_pro\20.1\embedded\cygwin_setup\https%3a%2f%2fcygwin.mirrors.hoobly.com%2f\x86_64\release\alternatives"
after these done, i tried to run the command again, now the cygwin was installed successfully!
now i believe this case can be closed and thanks for your support.
-----log as below-----
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\bash.exe --norc --noprofile "/etc/postinstall/zp_hicolor-icon-theme.sh"
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\dash.exe "/etc/postinstall/zp_man-db-update-index.dash"
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\bash.exe --norc --noprofile "/etc/postinstall/zp_shared-mime-info.sh"
Changing gid to Administrators
Ending cygwin installC:\intelFPGA_pro\20.1\embedded\cygwin_setup>
I think you need to list out the directory of setup-x86_64.exe after the command. I attempt to download cygwin and locate the .exe in my local disks. It ran successfully at the end.
