SOC EDS installation issue
- 4 years ago
i doubt my corporation firewall blocked the file download, and i tried to download the file "alternatives-1.3.30c-10.tar.bz2" from the link per the setup.log, then copy it to the foler: "C:\intelFPGA_pro\20.1\embedded\cygwin_setup\https%3a%2f%2fcygwin.mirrors.hoobly.com%2f\x86_64\release\alternatives"
after these done, i tried to run the command again, now the cygwin was installed successfully!
now i believe this case can be closed and thanks for your support.
-----log as below-----
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\bash.exe --norc --noprofile "/etc/postinstall/zp_hicolor-icon-theme.sh"
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\dash.exe "/etc/postinstall/zp_man-db-update-index.dash"
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\bash.exe --norc --noprofile "/etc/postinstall/zp_shared-mime-info.sh"
Changing gid to Administrators
Ending cygwin installC:\intelFPGA_pro\20.1\embedded\cygwin_setup>
1. The latest version available for SoC EDS Pro is v20.1. It is compatible to work with any version of Quartus Prime Pro Software.
2. SOC EDS v21.4 was not available currently.
3. It is not compulsory. You may use SoC EDS Pro is v20.1 with Quartus Prime Pro v21.4.
4. We don't have documentation for questions above currently.
Ean
Thank you for your reply.
Now i have installed Quartus prime pro V21.4 on my laptop(win10 OS).
and i am installing the SOC EDS v20.1 per instructions on below link:
https://rocketboards.org/foswiki/Documentation/SoCEDS#Install_SoC_EDS_AN1
I have installed the SOC EDS and ARM DS already.
now i am installing the Cygwin but error occurs with below logs. i tried several times with the same error. Will you pls help to check the reason and tell me how to do the next step?
-------------------error logs below-------------------------
2022/03/10 13:45:57 Downloaded C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/subversion/subversion-1.14.1-1.tar.xz
2022/03/10 13:45:57 download error in unattended_mode: 4 retries remaining.
get_url_to_file https://cygwin.mirrors.hoobly.com/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz.tmp
Checking SHA512 for file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz
SHA512 verified OK: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz 410b9d6dc8736f26350772da311d97f6f7a28e24e0c1f9ca2ece5eed6bf1758ab8a56f55e89affc784e0f28db90a5b170f384462a2b57f26a9f73ee971577e49
2022/03/10 13:46:11 Downloaded C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz
get_url_to_file https://cygwin.mirrors.hoobly.com/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2.tmp
INVALID PACKAGE: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 - Size mismatch: Ini-file: 73505 != On-disk: 10525
2022/03/10 13:46:14 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:14 download error in unattended_mode: 3 retries remaining.
INVALID PACKAGE: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 - Size mismatch: Ini-file: 73505 != On-disk: 10521
2022/03/10 13:46:16 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:16 download error in unattended_mode: 2 retries remaining.
INVALID PACKAGE: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 - Size mismatch: Ini-file: 73505 != On-disk: 10523
2022/03/10 13:46:18 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:18 download error in unattended_mode: 1 retry remaining.
2022/03/10 13:46:20 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:20 download error in unattended_mode: out of retries
2022/03/10 13:46:20 note: Download incomplete. Check C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\var\log\setup.log.full for details
2022/03/10 13:46:20 Ending cygwin install
