Krishnendhu1
1 year agoSetting up UART interface between DE10_Nano and PC without HPS or NIOS II
I want to setup the UART interface between DE10-standard board and the PC. From various articles available online, let me first brief the available options:- Method 1: Using HPS_UART_RX and HPS_UAR...
- 1 year ago
as stated, method 2 can't use onboard FT232 chip, method 3 can use it, but you need to configure HPS registers to setup the h2f loan_io routing. Means you need to write HPS code, compile and load it.Regards
Frank
BoonBengT_Altera
Moderator
1 year agoHi @Krishnendhu1,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
Krishnendhu1
1 year agoYes. My doubts are clarified
