malcolm_locke's avatar
malcolm_locke
1 year ago
SD Card Boot
I have an Agilex 5 Modular Development Board which I can boot with the supplied SD Card.
I have tried to update to the latest image at Index of /2025.04/gsrd/agilex5_mk_a5e065bb32aes1_gsrd/,
However, after programming an SD Card with this image, as far as I can tell, my board doesn't boot. I get no output from the serial port so I don't have any way of debugging.
Please can you help with any advice how to proceed to diagnose what is going wrong?
Many thanks
Malcolm
  • Hi Tiwari,
    Many thanks for your answer. After programming the QSPI with the image you suggested, I was able to boot linux successfully ( I believe from the SD Card!).
    Please can you give a brief explanation as to why this was necessary? What was preventing linux from booting?
    Many thanks
    Malcolm
  • Jeet14's avatar
    Jeet14
    Hi Malcolm,
    I hope you have reprogrammed the new .jic image to QSPI before using the sd card image.
    This .jic image is given on the same link-https://releases.rocketboards.org/2025.04/gsrd/agilex5_mk_a5e065bb32aes1_gsrd/
    Please confirm.
    Tiwari
