AJama4
7 years agoRunning bare-metal from SDRAM memory. Error
I am using De1-SoC board. Cyclone V (Cortex-A9). As far as I understand the base address of the SDRAM memory in the MPU address space is 0x00100000 and the ending address is 0xC0000000 by default. It...
AJama4
7 years agoI have generated two separate preloaders for two separate Quartus projects but in the end the serial terminal's output is the same when I try to load the preloader using DS5 debugger.I think I didn't ask my question clearly. My question is, if its not working with the standard GHRD preloader for the De1-SoC board, then how can I change the settings or what additional should I do? I know already the whole procedure how to generate the preloader using BSP-editor and its various options.
- EBERLAZARE_I_Intel7 years ago
Assuming you have generated the preloaders correctly;
1) Can you check the BSEL pins of the board if they have been set properly?
