AJama4
7 years agoRunning bare-metal from SDRAM memory. Error
I am using De1-SoC board. Cyclone V (Cortex-A9). As far as I understand the base address of the SDRAM memory in the MPU address space is 0x00100000 and the ending address is 0xC0000000 by default. It...
EBERLAZARE_I_Intel
7 years agoHi,
To generate and compile the preloader I highly recommend you check here (For Cyclone V), in Procedure tab there are also Screenshots of the procedure for your reference to guide you better:
https://rocketboards.org/foswiki/Documentation/GSRDPreloader
In general, you could also check other topics/tasks for Cyclone V such as compiling the Hardware Design etc.:
https://rocketboards.org/foswiki/Main/GettingStarted
From above link, choose your board, Cyclone > then your Quartus Version > Task you interested in.
