Hi, I have an Agilex 5 Modular Development Board which I can boot with the supplied SD Card. I have tried to update to the latest image at Index of /2025.04/gsrd/agilex5_mk_a5e065bb32aes1_gsrd/, H...
for the Boot from QSPI but have given up as, having got around a number of errors, I managed to create and program my QSPI, only for to fail to boot (I can't even open the Serial Port), at which point I have no way to debug what is happening...
One error that I have relates to bl31.bin which i built successfully in the Boot from SD Card stage, but when I run bitbake in the QSPI stage, i get this error:
DEBUG: Executing shell function do_compile cp: cannot stat '/home/malc/agilex5_top/yocto/build/tmp/deploy/images/agilex5_dk_a5e065bb32aes1/bl31.bin': No such file or directory WARNING: /home/malc/agilex5_top/yocto/build/tmp/work/agilex5_dk_a5e065bb32aes1-poky-linux/u-boot-socfpga/v2025.04+git/temp/run.do_compile.19724:163 exit 1 from 'cp /home/malc/agilex5_top/yocto/build/tmp/deploy/images/agilex5_dk_a5e065bb32aes1/${file} /home/malc/agilex5_top/yocto/build/tmp/work/agilex5_dk_a5e065bb32aes1-poky-linux/u-boot-socfpga/v2025.04+git/build/${config}/${file}' WARNING: Backtrace (BB generated script): #1: do_compile, /home/malc/agilex5_top/yocto/build/tmp/work/agilex5_dk_a5e065bb32aes1-poky-linux/u-boot-socfpga/v2025.04+git/temp/run.do_compile.19724, line 163 #2: main, /home/malc/agilex5_top/yocto/build/tmp/work/agilex5_dk_a5e065bb32aes1-poky-linux/u-boot-socfpga/v2025.04+git/temp/run.do_compile.19724, line 301
PS. I am using WSL2.
In the boot from QSPI section, it is unclear what, if anything I need to do with the SD Card...
This section presents how to boot from QSPI. One notable aspect is that you need to wipe the SD card partitioning information, as otherwise U-Boot SPL could find a valid SD card image, and try to boot from that first.
Wipe SD Card
Either write 1MB of zeroes at the beginning of the SD card, or remove the SD card from the HPS Daughter Card. You can useddon Linux, orWin32DiskImageron Windows to achieve this.
Write QSPI Flash
1. Power down board
2. Set MSEL dipswitch S4 on SOM to JTAG: OFF-OFF
3. Power up the board
4. Download and extract the JIC image, then write it to QSPI:
Related to the errors that you are seeing when building the binaries, it's possible that a package could be missing in the WSL2 environment when building the RootFS, but what is weird is that in this page https://altera-fpga.github.io/rel-25.1.1/embedded-designs/agilex-5/e-series/modular/boot-examples/ug-linux-boot-agx5e-modular, you just use the rootfs in the Linux boot stage and shouldn't affect that you see something on the serial console. The U-Boot SPL is the first binary that HPS executes and this is included as part of the bitstream provided to the system. This bitstream includes the hardware design(.sof) and the SPL(.hex):
In the case of booting from SD Card:
In the case of Booting from QSPI:
If the hardware design(.sof) and the SPL(.hex) were created correctly, you should be able to see an output from the serial console. here you also need to double-check that in your devkit, the msel is set to QSPI so it can read the bitstream from the QSPI.
If you have problems generating the RootFS, you can get this directly from the Pre-Built binaries included in the correct paths provided above.
