GQUIR2
5 years agoI'm using "EDS Command Shell" running on Win 10 PC. How can I check if correct Toolchain is installed?
Is there manual how to install toolchain under "EDS Command Shell"?
Gerhard
- EBERLAZARE_I_Intel5 years ago
Unfortunately, the building bootloader tutorial is targeting for Linux host users it is not meant for Windows 10 users.
If you opt to use Windows 10, I recommend that you use Quartus and SoC EDS 18.1 std, and use the bsp-editor flow.
If you wish to, you may install a virtual machine and learn Linux, it is pretty simple since you are going to use Linux in Cyclone V SoC anyway.
Regards.
