fatal error: cstdarg: No such file or directory
- 5 years ago
I solved the issue. I think this is an eclipse IDE issue.
I add 2 more paths to Application Include Directories, which is under Properties>Nios 2 Application Properties>Nios 2 Application Paths, then change my main. c to main.cpp
I attached the paths.
- BoonBengT_Altera5 years ago
Moderator
Hi @burakduysak,
Thank you so much for sharing the solution here and apologies for the inconvenient cause.
With that we would proceed to close this threads, any issues faced in the future we can always pots a new thread or response to this thread on the next 5 days.
After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.Warm Regards
BB
