JFull1
7 years agore: Cyclone V 5CSXFC4C6U23C7N LPDDR2 Why an unexpected SDRAM refresh behavior?
Using 5CSXFC4C6U23C7N CycloneV with 2x MT42L128M32D1LF-25 WT:A LPDDR2 Micron SDRAM: 4Gb (2Mx32b x 8bank) Quartus Prime 18.1 Lite Edition We have noticed a curious feature of the fpga SDRAM: ...
JFull1
7 years agoBCT
Thanks again, it was the DQS tracking feature that surprised us.
We don't have a file like *_if0_c0.v but we found *_fmem_s0.v that
works. I have two follow-on questions:
1.How can we permanently stop DQS tracking?
We can stop it with this before compiling,
but the file is overwritten by Qsys/Platform Designer:
sth31_fmem_s0.v: sequencer_scc_mgr #( .USE_DQS_TRACKING (1), -> "0"
BTW, I've found several other files that reference DQS_TRACKING that are
overwritten by Qsys but hacking just them before compiling does not
change the fmem dqs tracking behavior:
sequencer\emif_pre.xml <sequencer> <define name="USE_DQS_TRACKING"
value="1"/> -> "0"
<controller> <define
name="USE_HPS_DQS_TRACKING" value="true"/> -> false
sth31_fmem_p0_altdqdqs.v defparam altdq_dqs2_inst.USE_DQS_TRACKING =
"true"; -> "false"
sth31_fmem_s0_make_qsys_seq.tcl lappend arg_list
"--component-param=USE_DQS_TRACKING=true" -> "false"
hps_sdram_p0_altdqdqs.v defparam altdq_dqs2_inst.USE_DQS_TRACKING =
"true"; -> "false" [not fmem]
2.Disabling FORCE_DQS_TRACKING in .qsys before generating seems to stop
normal refresh, as well as dqs_tracking.
is this intended?
(if so, the name is deceptive)
Thanks in advance,
John
Den 2019-08-13 kl. 04:52, skrev Intel Forums:
BoonT_Intel
7 years agoHi John,
Yes, regenerate qsys will overwrite the hacking. I don't think we need to always re-generate the files.
I think we only need to hack the master file, for other file, it just a reference only.
I don't think it will disable the refresh as well. If without refresh, the memory module unable to retain the memory correctly.
