CRubi
7 years agoQSPI NOR flash boot programming
I'm transferring 64MB of qspiimage.img image to QSPI NOR S25FL512 flash on our custom board (uses A10SoC same as GHRD design). It takes a long time to finish the image transfer (>2hr). I’m fo...
Ahmed_H_Intel1
7 years agoThank you Georgi for your comment,
Hello Allen,
This approach will be always slow. But once you flash-ed the image then the update could be done quite fast depending from few things.
networking support in that linux image
mtd utils present in linux image
Once programmed the image, you will be able to transfer the next image file into DDRAM (ramfs) with ftp or sftp and then usind mtd utils (flashcp, flash_erase, etc...) to program the image to the device. it will be significantly faster.
