ZZhan108
6 years agoProblem on downloading bitstream to a Stratix 10 MX board
Hi all, Now I'm trying to programming the Stratix 10 MX board with a simple test example (4-bit counter). Following are my hardware and software info: Software: Quartus Prime Pro 19.3 Hardware: St...
JohnT_Altera
6 years agoHi,
May I know if you are observing it during the starting of powering the board? May I know if you facing the same issue when you remove the board from the system and power on the board using the external power supply?
