Anu_Jayan
3 years agoPrimary and secondary boot in Cyclone 10 GX Development Kit
Hi
1) I would like to know how to load the boot-loader in Cyclone 10GX development kit.
2) Can I know how to flash secondary boot-loader through QSPI flash? It would great if you share any proce...
aikeu
3 years agoHi user_aj,
The standard building bootloader of Cyclone V is from the below document:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
Since you mentioned about the U-boot, you can just refer to the U-boot section.
Before that, do determine how your system going to boot up first. If for QSPI flash can check the particular section from the document regarding the method to build/flash and boot up with QSPI flash.
Do let me know if you require more info.
Aik Eu
