ainsley26
7 years agoPreloader `make` failed while including include/autoconf.mk.dep
After following the fix here to rectify issues with extracting the tar file containing u-boot; the `make` command to build the pre-loader fails. In particular: ...
make[1]: Entering directory '/cy...
FawazJ_Altera
7 years agoHello,
I have tested /usr/bin/make and it worked fine here.
May I know if you changed something in bsp-editor before using make?
Thank you
