On Arria10, how to measure time from power-up
Hi Yoels,
Hi Yoels,
The booting time for uboot on an Arria 10 SoC FPGA can vary depending on factors such as the U-Boot version, configuration settings, and the specific hardware , booting source such NAND, QSPI, SDcard or etc and peripherals used.
Rough estimation, uboot boots in a matter of seconds, often around 5-10 seconds.
but , the actual boot time can be longer or shorter depending on the complexity of your specific uboot, configuration and the functions needs to perform during booting.
To get a more accurate, measurement can made be using timestamp signals or debugging tools to measure the boot time for your particular setup.
I also need to figure out how to create a time stamp using uboot.
Intel does not support vxwork for this.
Thank you,
Aliff
