My First HPS error
And for the same project, there is another error when I was trying to generate header file with generate_hps_qsys_header.sh script. I attached the screenshot of the error message as well. Any solution to this problem?
- MV5 years ago
@Patrick77
Any luck there? If it helps - I am having the same issue. Reinstalling the tools for the third time, searching for the missing file in an entire filesystem (so I eliminate path questions) and no success.- Patrick775 years ago
Hi MV,
Sorry for the late response. I don’t know if you have solved it yet.
It seems that v20.1 is not very stable so my solution is very simple: just use Quartus v18.1 instead of v20.1. Everything works fine after that.
Hope this works for you as well. **bleep** luck.- MV5 years ago
Hi @Patrick77 ,
Not too late - trying to solve some independent issues (understand how to communicate with the FPGA) so I didn't make much progress.
I have installing Quartus in Ubuntu VM on my list but perhaps I will try Quartus 18.x first as you suggest.Thanks - M
