MMuth8
6 years agoMAX10 FPGA CFM size
Hi, I am using MAX10(10M25DAF484C8G) FPGA and internal configuration memory(CFM) for FPGA code. For Single uncompressed image configuration mode, generated the files(through convert programming fi...
AnandRaj_S_Intel
6 years agoHi Mahalakshmi,
- .sof used during JTAG configuration programs the CRAM only and does not contain ICB settings or CFM. We can use compression if the sof file is not fitting. While programming internal flash we have to check the hardware image size, refer to the .map file generated during .pof file generation.
- Refer section 1.7.4 of an741 Updating Image and Triggering Reconfiguration using UART.
Examples:
https://fpgacloud.intel.com/devstore/platform/15.1.0/Standard/i2c-remote-system-update-example/
https://fpgacloud.intel.com/devstore/platform/15.0.0/Standard/max10-remote-system-upgrade-rsu-over-uart-for-nios-ii-processor/
Anand
