make (e=2): The system cannot find the file specified
Hi
Please make sure that you are inside the SoC EDS shell while you are running the make commands. Your SoC EDS shell needs to be started before running the embedded code.
Please find the link , below for further reference on how to run EDS under Windows
https://rocketboards.org/foswiki/Documentation/SoCEDS?t=2020-04-17T22:46:12+00:00
Also below forum post can also help you to debug make file related issue.
Thanks and Regards
Anil
Thank you for your reply. The link to rocketboards.org is enlightening, especially the part about installing linaro and MinGW, neither of which is mentioned in the documentation that I found from Intel or Terasic. That is very disappointing, I spent a lot of time trying to install not knowing this. After following those instructions, I was still having the same problems with make and have run out of enthusiasm to make this work and plan to use a device and tool flow that I have been comfortable with. I will come back to this at a later date.
Another thing that has been unclear to me is the licensing of the ARM development software. I am currently using a temp license. I see references in Intel docs that a license is provided with the development board, but that seems to only apply to Intel development boards. It seems that even though I have a license for Quartus I still need to purchase an ARM license in order to use a development board from Terasic.
- AnilErinch_A_Intel6 years ago
Hi
The Rocketboards is also a forum supported by Intel.
You have to get a license from ARM , since DS 5 is used for the SoC EDS.
Please see the link below for licensing related information.
Thanks and Regards
Anil
