IP integration in platform designer
I have two ips which I like to join them in platform designer. One is a qsfp and the other is emif.
These two designs have right parameter setup.
Now I open up a new platform designer under the same project name and add these ips under tool/option tab into ip directory.
They show up under existing ip variants. When “Add” them they lose all connectivity and names find originally in their qsys set originally.
What I was hoping was the ability to move the entire IP as it is set and then apply modifications in Platform designer.
Is that possible?
How can I preserve/package the entire design (keep the original setup) and then import it into the new design.
Hi Ramin,
I suggest you to go through this link below on how to Create Qsys Components. Refer to link below for more details.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qsys_components.pdf
- SyafieqS
Hi Ramin,
- Ramin
Thank you for the link.
- SyafieqS
Hi Ramin,
Any update regarding this?
