Install Tensorflow on DE10-NANO
Is there have a document for installing TensorFlow on DE10-NANO?
I can install TensorFlow successfully, but when I use TensorFlow to do something, I get "Illegal instruction",
for example :
sess = tf.Session()
a = tf.constant([[2, 2, 2], [3, 3, 3]], dtype=tf.float32)
b = tf.constant([[1, 1, 1], [2, 2, 2]], dtype=tf.float32)
print(sess.run(a))
print(sess.run(tf.add(a, b))
The code above can work, but when I use the other code like "tf.subtract(a, b)", I will get
"Illegal instruction".
How can I fix it? thanks
- JohnT_Altera
Are you refering to running the Tensorflow in the ARM processor? If yes, may I know what is the OS you are running with?
- nickis666
Yes, and I use the LXDE(Linux LXDE Desktop (kernel 4.5)) from this website:
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=205&No=1046&PartNo=4
thanks!
- JohnT_Altera
I would recommend you to contact Terasic on this issue as the OS was created by them
- TrivenNTHU
I would recommend that you can try this, modern Linux kernel on de10-nano.
