matif
7 years agoInconsistent Data of Transceiver
Hi all, I am printing my data from trasnceiver at UART output terminal (putty). My setup consists of a counter running at 100 Mhz. this counter is connected to transciever. The transceiver pll cloc...
CheepinC_altera
7 years agoHi,
Thanks for sharing the info on the Arrow SocKit eval board. For your information, as I look into the start guide (https://rocketboards.org/foswiki/pub/Documentation/ArrowSoCKitEvaluationBoard/SoCKit_Getting_Started_Guide.pdf) , I notice that the board has built in USB Blaster II. You can refer to the Figure 3-5 USB and Power Cables. It is a microB USB connector. Generally if you directly connect a USB cable to this, your Quartus will be able to detect and program the CV device through JTAG. You can use SignalTap with this USB Blaster II. Just would like to check with you how do you program the CV device currently?
Chee Pin
matif
7 years agoThanks a lot. Just checked. The usb blaster is working. Thanks a lot again. Now I can use SignalTap with this USB blaster II. Thanks a lot again for your support.
I shall Keep you inform of further Progress.
Sent from Mail for Windows 10
- CheepinC_altera7 years ago
Thanks for the update. Glad to hear that the USB blaster is working. Please feel free to keep me posted on the RX status and RX Parallel data check in signaltap. Thank you. Best regards, Chee Pin
