Inconsistent Data of Transceiver
As I understand it, you seems to observe some issue with RX parallel data output display at UART output terminal.
By the way, I notice that you have filed another case 04274469, just would like to check with you if both of the cases 04274469 and 04274941 are similar? If they are the same, then we could follow up using a single case for better tracking purpose.
Regarding your RX parallel data output issue, we would require further debugging to further narrow down the issue. Just would like to check with you on the following:
1. Just wonder if you have had a chance to SignalTap the transceiver RX parallel data output to see if the output is something expected?
2. You may also cross check the SignalTap data with the UART terminal to see if there is any discrepancy.
3. Would you mind to share with me your transceiver Native PHY's .qsys file so that I can have a better understanding on your transceiver configuration.
Chee Pin
