Hwlib example preloader questions
Update 2023/5/12
I've tried the branch origan/2020.04
with make socfpga_cyclone5_defconfig
and it worked.
if it is after 2021 the preloader will showed up the error mentioned.
you guys can try 2022 branch with higher version of ARM DS.
Or there is some settings on newer version u-boot you must set i guess.
- CAlex3 years ago
Contributor
Update 2023/5/12 v2
Now I'm doing two tests
1. Run Example FPGA using GCC with error:
process_begin: CreateProcess(NULL, cp C:\intelFPGA\20.1\embedded/ip/altera/hps/altera_hps/hwlib ., ...) failed.
Maybe the reason is no permission to copy from C:\
Or duel to some environment issue.
I started the ARMDS with SOCEDS in WSL2 Ubuntu 18.04 LTS , but it still saied it cant find SOCEDS_DEST_ROOT. So I pointed the SOCEDS_DEST_ROOT to SOCEDS_ROOTDIR.
2. Run Example FPGA using ARMCC with error:
D:\board\cyclone_V_soc\intel-socfpga-hwlib\tools\newlib\usr\arm-eabi/include\sys/_types.h:167:5: error: unknown type name 'wint_t'
wint_t __wch;
1 error generated.I ran it with Armclang (arm compiler 6) since I didnt have the access on 5 with a little changes on makefile. All went well except for this error.
Do you guys have any solutions?
- CAlex3 years ago
Contributor
Update 2023/5/12 v3
While doing example of cp .sof, there is no cycloneV GHRD under SOCEDS /hardware file. Only A10 GHRD ones.
For real, have you ever planned to update the SOC?
