HWlib baremetal project issue: How to devide the codes.
HI Alex
After merging both files into one is it still having issues?
What error that you seen previously?
Jingyang, Teh
- CAlex3 years ago
Contributor
No,
it didnt happen any more.
BTW,
could I ask a question about debug?
While using SPL-debug.ds, it will stop at spl-boot-device function.
Usually I will do F8 to let it ran and disconnect.
But sometimes when I re-connect the SPL-debug.ds it will have a invisiable breakpoint at spl-boot-device, I cant step and run, I can only do jump to continue.
The same thing happened in main function as well, when I make a breakpoint(red dot,which means DS soft breakpoint?), I cant step/jump/continue the function. Actually when I do the step,it will only step till the main function reaches. The only thing I can do is disconnnect, cancel/add the breakpoint and reconnect again.
And then it will automatically do the main function even when I want to do the step.
I wrote some timer ISR and enabled some timers,is that the reason?
