HPS2FPGA Bridge Throughput
I am working on a project where there is a DDR4 RAM connected to the HPS2FPGA bridge and the host sends data to be saved in the RAM. I am trying to improve the throughput from the HPS to the DDR4, but the fastest I have achieved is ~16MB/s.
The software is written in C and the system is running embedded Linux. I am using the mmap() function to write the data to the DDR4 RAM. The program just writes large chunks of data to RAM. I am using an array of memory mapped locations in the example, but the rate is the same with only one map.
numOfBytes = 0x1000000;
for(i = 0; i < 32; i++)
ret = BridgeMap(HPS2FPGA, i * numOfBytes, numOfBytes, &ddr4Map[i]);
ddr4Reg[i] = (unsigned int *) (ddr4Map[i]);
for(j = 0; j < numOfBytes/4; j++)
ddr4Reg[i][j] = i;
}int BridgeMap(int bridgeType, int address, int numOfBytes, void ** pMap)
if(fd_bridge == -1)
return -1;
int bridgeOffset, pageAlignedAddress;
if(bridgeType == LWBRIDGE)
bridgeOffset = LWBRIDGE_START;
else if(bridgeType == HPS2FPGA)
bridgeOffset = HPS2FPGA_START;
pageAlignedAddress = (address / 0x1000) * 0x1000; // get page aligned address
*pMap = mmap(NULL, numOfBytes, PROT_READ | PROT_WRITE, MAP_SHARED,
fd_bridge, bridgeOffset + pageAlignedAddress);
if(pMap == MAP_FAILED)
printf("error mapping: %s\n",strerror(errno));
return -1;
return pageAlignedAddress;
}How can I improve the data rate going from the HPS to RAM? Is there a better way to communicate data from the HPS through the HPS2FPGA bridge? Should I be using the F2SDRAM bridge instead?
Thank you
- FawazJ_Altera
The fastest way of transferring data between HPS and FPGA would be the use of DMA. memcpy and mmap are slow.
You can refer to the datamover example:
https://rocketboards.org/foswiki/Projects/Datamover
where it shows you how to transfer data from HPS to FPGA and vice versa.
Please let me know if you need further assistance,
thanks
- SrLam9
Where can I find the example files? When I click the link for the zip file, the directory is empty aside from the README.
Also I looked over the example (maybe the source files can help clarify), but something is still not clear to me. In my application, I would be receiving data from a host PC that needs to be saved on to RAM. The data comes in via Ethernet, and it ends up in an array after it is read. How do I transfer that to RAM or how can I find where that is located since the sgDMA needs a source and destination address.
Thank you
- FawazJ_Altera
I will check with our admin regarding the missing files. Once I get a feedback I will let you know.
Thank you
- FawazJ_Altera
the design files has been removed since it was built with an old Linux version. I will try to migrate the design to a newer linux OS and send them to you.
Thank you
- FawazJ_Altera
The design files cannot be migrated due to kernel module dependencies.
I am still working on getting a workaround to overcome this issue,
Thank you
- SrLam9
Thank you, Is it possible to send me the old files first? I want to take a look at the code itself. Especially the HPS code to see how I can implement something similar on my end. -Sid
- FawazJ_Altera
My apologize for the late reply. I was able to fine the design files (excluding the kernel zImage file). It took some time to fine the linux module source code.
I am still working on the alternative solution which might take extra time to verify.
- FPOPP1
I am also trying to start the data mover. This could be very useful in teaching SOCFPGA.
Any chance to have it up and running in the actual tool landscape / linux version?
