YaronAnkori
3 years agoHPS Uboot QSPI Arria10 Evaluation board
Hello, EVB: Arria10, HPS. Quartus Version 16.1. We succeeded to create and compile UBOOT via the ARM “bsp-editor”(Quartus 16.1) tool for the SD-CARD, and to run the application “Hello world” . ...
aikeu
3 years agoHi Yaron,
Try with the pre-built binaries or build the u-boot folllowing the latest building bootloader document.
I have no problem to use sf probe on my side with Arria 10 soc board before i can perform sf read/write.
Aik Eu
YaronAnkori
3 years agoHi Aik,
The problem was solved. It seems that something is wrong with the bsp-editor tool.
The best way to generate the UBOOT is to use the terminal and commands as described in this link:
https://www.rocketboards.org/foswiki/Documentation/A10GsrdQspiBootLTS
Many thanks for your support.
Yaron Ankori
