HPS Uboot QSPI Arria10 Evaluation board
Hi Yaron,
The default gsrd can be found in the link below, can check by going back to the top folder of the link for older version.
https://releases.rocketboards.org/2023.04/gsrd/a10_gsrd/
The method to determine what bootloader files to use and flash to qspi can be found in the building bootloader(QSPI) in the link below:
So previously you are not able to boot with qspi then you used sdcard boot to u-boot in order to perform sf probe cmd if I understood you correctly?
Aik Eu
- YaronAnkori3 years ago
Hi Aik,
I succeeded to boot the application via SDCARD on the first stage. There is no problem with SDCARD.
In the second stage I change the bsp-editor tool configuration to boot from QSPI (and the handoff file too) , also replaced the hardware from SD CARD to QSPI on the Arria 10 EVB.
The UBOOT stops in the middle. I can see the UBOOT print That the UBOOT is looking for MMC although the configuration was for QSPI.
