aduru
7 years agoHow to reach and configure EMMC part of Arria 10
I am using SD/MMC card for booting Arria 10 to debug some stuff but now I want to change booting from SD/MMC to EMMC . Altough I have searcht many sites and read every documents, I can not reach EMMC...
SreekumarR_G_Intel
7 years agoActually eMMC and SD card flashing method both are same.Create the img file as you create for SD card and flash to the eMMC.
HPS boot pins even shared both the same for the SD or eMMC flash.
if you notice all the handbook/userguide mention as SD/MMC.
Thank you ,
Sree
- aduru7 years ago
The main problem is that I can not see eMMC part of the boards so that I can not flash to eMMC.I have already img files that are SD card and I am booting board from SD card .By the way the boards that I am using is Mercury AA1 and Mercury PE1 .
Thank you for answer :)
