How to customize the Agilex 7 I-series OS build with SOF and HPS changes ?
Hi
You could take a look at the link below for the GSRD for the Agilex7 I series devkit.
Please find the answers below:
1.Apart from the SOF file, what other file needs be generated from Quartus Prime ?
For sof it is a volatile configuration. For a non-volatile configuration you would need the RBF or JIC format.
2.Where is the dts, which we can customize for HPS & FPGA-HPS ?
For the Agilex7 you could find the device tree here:
https://github.com/altera-fpga/linux-socfpga/tree/socfpga-6.12.11-lts/arch/arm64/boot/dts/intel
3.What's the build flow for such a customized design. Since the guide only explains about the GSRD, Can you explain the flow for custom designs ?
You could refer to the link below for the boot flow:
Jingyang, Teh
- sujan191 year ago
Hi Jingyang,
Thanks for replying.
- This Guide for GHRD is for f-series SOC, does this apply for I-series as well?
- And correct me if i am wrong, should we use our custom design's SOF file to build the ghrd.hps.jic image in this command :
quartus_pfg -c \ agilex_soc_devkit_ghrd/output_files/ghrd_agfb014r24b2e2v.sof \ ghrd.jic \ -o device=MT25QU128 \ -o flash_loader=AGFB014R24B2E2V \ -o hps_path=u-boot-socfpga/spl/u-boot-spl-dtb.hex \ -o mode=ASX4 \ -o hps=1
instead of one built by this git repo : https://github.com/altera-opensource/ghrd-socfpga- If yes, what other file do we need to generate apart from SOF file to generate .jic and .img files ?
- We also have this file hps_bootloader_handoff_bringup.bin , what is use of this ? and where is it used ?
Sujan
