KSwam3
7 years agoHow to connect2 Avalon MM masters to 1 MM slave
I am going to be using the EMIF IP to connect to a DDR4 memory. I have 2 MM masters trying to access the memory. I am trying to come up with a design in Qsys and cannot understand how to go about thi...
- 7 years ago
Yes, in Platform Designer (Qsys) you simply connect both masters to the same slave interface of the IP. You can do this in the Connections panel of the System Contents tab (clicking the correct dots) or select the slave interface there and open the Connections tab from the View menu and use the checkboxes there.
KennyT_altera
7 years agoJust connect those in Qsys, it should handle the adaptation for you.
